DogDipstick
One thousand watt hours on each side. Pic heavy.
Replacement of my old battery with a newly built.
I will then post some of my other batteries, that I have built for friends, and pictures of the system I use and am comfortable with. Ask me anything about my builds, i love to share info with fellow ebikers and battery builders.I would love to hear your experiences too. Be free.
All 100% recycled EV cells. 2019 Chevrolet Volt.
Old Faithful, ~180wH/kG, 15Ah, 72v,..... Unknown age. Unknown cycles. Cells were circa 2015, from an unknown battery, purchased on through eBay from Art at Green Tec Auto ( good seller, if you like recycling. ) . From a poor Chevrolet Volt Gen 1 car that perished some time along the way.
.... to a 204wH/kg, 1.8kWh nominal, 25Ah, 72v pack. 6AWG silicone wire, 200A fuse, easy 10C capable continuous. Lets not even talk about peaks. Lets just say it will peak very high. Brand new cells, acquired from a Chevrolet dealership going out of business in Ohio. Result of the the Pandemic. 2019 cell. LGZ P2.7 is the name printed on the cell.
Black CNC machined polycarbonate case. The battery will live in this case for the rest of its life. That is the plan. 200A MIDI fuse, 1/4 inch thick poly machined on a cnc router, and bent on a high wattage poly carbonate bender (home made design,). Both side covers are easily removable for maintenance. There is a port, connecting both halves, to carry the power 6AWG and associated battery series circuit.
2x 10s, 25Ah, each 900wH. One on each side of the bike.
6AWG silicone and Panduit, 1/4 inch lugs serve everything high current.
2x DB15 ports, to serve the cell level balancing connections.
20AWG on, Cannon gold pins, to serve the BMS cell level taps. This harness has not been built yet, but will serve the entire battery ( both sides) when hooked up and charged through a BMS.
8AWG chargin line protected by an ANL fiberglass and mica fuse.
Decorative side panels to be installed, clear CNC cut poly carbonate. Might also cover up the panel screws with this piece. .. I dont know. To be installed ( with the terminal mount for the DB15 connections cut in).
Charge # 1.... and counting.
