d3drturner
- Joined
- Apr 14, 2019
- Messages
- 3
I have a battery of 10s3p LGABHE41865 2500mAh 20A.
Cells come from a 60v Greenworks lawnmower that was used one time and failed to charge after that.
Suspecting a bad BMS I took the battery apart and tested each cell which tested nearly identically.
I re-welded these for 36v 10s3p using BMS SP15SV0001-LLT from lithiumbatterypcb.com
Used lightly for a couple years in my grocery getter.
Parallel set 2 is lagging behind the others; at full charge it shows 3.9 vs 4.2 for the others
I thought I might replace the #2 set with 3 new LGABHE41865
However, I can't find them for sale anywhere.
What should I do about this? Junk the whole battery? Use some other equivalent cells to replace the low set?
Is this BMS failing to balance the #2 set?
