recumpence
1 GW
Hey Guys,
Here is one of my latest projects. FFR trikes and I have collaborated on this. It is my idea, design, and funds, with their CAD work.
This is the first we made (I have two on hand to mount to my yellow trike). This rotor is being developed in an attempt to increase braking power, while decreasing rotor heat and pad wear from overuse. I blue the rotors on all my bikes. This should cure that while adding more braking power to our heavier than stock bikes.
This rotor is a prototype. I hope to offer these for sale within a month or so. The rotor itself will sell for somewhere around $45. The caliper mount will be another $40 to $45 depending on the design and machining time.
I have not tested this rotor yet. It was lazer cut from stainless (I think it was 303?). The lazer shop provided the material and said it was the hardest they had in stock. So, we will see how well it wears. Obviously, material type is important on a brake rotor. So, I need to get this one tested and try other materials as well to find the best option.
Anyway, I will let you guys know when they are available.
Oh, the one picture is of the rotor on a KMX 16 inch front wheel. I wanted to make sure the rotor was large enough to give the maximum braking power, while being small enough to use on the front of KMX trikes. :wink:
Lastly, this rotor weighs 356 grams.
Matt
Matt
