I'm assuming the most typical rear dropout on an MTB is 10mm nominal (mine is 10.4mm actual) and 135mm width. Most hub motors designed for this size have a 12mm axle that is ground down on each side by 1mm.
This is how an actual 12x10 axle will look like in a 10mm dropout (well, 10.4mm in the illustration).
Filing away 0.4mm of material will make it sit flush. But does it really matter?
