recumpence
1 GW
24,000 watts helps.
recumpence said:24,000 watts helps.![]()
Rix said:recumpence said:24,000 watts helps.![]()
Yah, I imagine it does. I think bursting 24kw through my hubmotor, would drastically reduce the life span. Hell 11kw gets it warm pretty quick, thats not even half what you got going on.
recumpence said:I have to say; setting up and tuning these systems requires very specific knowledge and skill gleaned over years of experience (screwing things up, blowing controllers, ruining bearings and belts, etc). This bike is the pinicle of all I have learned. What I mean by that is not so much that the performance is the highest I have ever had (though it is close), but that I have learned how to setup these systems up and program the controllers to make the performance accessible and controllable. This bike exibits the best balance of performance and ride-ability. It is super powerful without being uncontrollable.
DAMN! I want to see that too!macribs said:I think for the power to weight ratio Matt might have been higher on previous build. Iirc the bike in his avatar was triple astro 3220![]()
Another lightweight yet very powerful bike is the top secret build that Toolman2 did with the joby motor. Still waiting for him to share more on that one :lol: He did actually race that bike and outrun 450cc on a "speedway" track, and in another video he was racing a dirt/gras track and overtaking all the gas gusslers coming in as #1.
recumpence said:RC based systems get a bad rap primarily because people who set them up incorrectly or build them incorrectly to begin with complain that RC Systems will not work properly or will not work reliably. However, as I just mentioned, if properly set up they are powerful very efficient very lightweight and very reliable at the same time.
Rix said:DAMN! I want to see that too!macribs said:I think for the power to weight ratio Matt might have been higher on previous build. Iirc the bike in his avatar was triple astro 3220![]()
madin88 said:recumpence said:RC based systems get a bad rap primarily because people who set them up incorrectly or build them incorrectly to begin with complain that RC Systems will not work properly or will not work reliably. However, as I just mentioned, if properly set up they are powerful very efficient very lightweight and very reliable at the same time.
Only problem i see with RC based drives is the lack of real torque control.
have you thought about trying a VESC controller? Version 6 is available soon, and it has FOC control.
It "only" can do something like 2-3kW, but maybe it is possible to modify the power stage for your demands![]()
DAMN! I want to see that too![macribs said:I think for the power to weight ratio Matt might have been higher on previous build. Iirc the bike in his avatar was triple astro 3220![]()
One thing to remember when discussing power and weight;
There is an important facet of vehicle dynamics called balance. The chassis, brakes, and suspension must balance each other out to maximize the driving (or riding) experience. A little overpowered can be fun. But, there is such a thing as being too powerful fire general day to day use. This seems especially important in two wheeled vehicles. In my builds (and my preference), 10 pounds per HP is a great ratio. My Motoped and this Raptor hit that number (with my 180 pound body on board). This combined with a 40mph top speed gearing makes for a wonderful, thrilling, extremely fun combination without being stupidly over powered and hard to ride. And even then, these bikes are only rideable because of clever programming in the controllers to tame the hit a little bit.
3 motors was downright dangerous on that small 80 pound bike.
In fact, I have found my 50 pound, 6kw peak power Mountaincycle nearly perfectly balanced geared for 30mph hot of the charger.
Alex07 said:One thing to remember when discussing power and weight;
So out off all your different setups you tried up to 18kw peak, the 6 kw peak is the perfect power for a balanced setup - when single speed geared for 30mph; then how much better would that 6kw power be with the torque multiplication of multiple gears vs fixed 1 gear? i.e on the Tangent mid drive 3220 6kw or AFT 6kw mid drive ? you theoretically would have better acceleration on take off and a better top end as well ? The hard part is making the gear system handle it, we will find out how they work soon as their is a few 6kw mid drives coming out i see on recent builds...
Kepler said:My FUTR 29'er fits into those power to weight parameters. Its a beast that needs to be treated with respect or it will bite you. But as you say, its not crazy power and a very enjoyable and exhilarating bike to ride. Of cause not the same balance as mid drive bike like yours but I think the dead silence of a sinewave controlled hub motor has its own certain appeal.
In my case, I am including my body weight. I am 180 pounds, the bike is 125 pounds, and the power is roughly 30Hp peak.Rix said:Kepler said:My FUTR 29'er fits into those power to weight parameters. Its a beast that needs to be treated with respect or it will bite you. But as you say, its not crazy power and a very enjoyable and exhilarating bike to ride. Of cause not the same balance as mid drive bike like yours but I think the dead silence of a sinewave controlled hub motor has its own certain appeal.
WIth you John, my Alpha build with settings turned down to about 8kw falls into the weight parameters Recumpence mentioned. Actually, about 1hp for every 9 pounds is where I am at. Really is about ideal as far as fun and ease of handling go. It will still loft the front wheel off the ground with ease.
Kepler said:Sorry, miss understood. That is a completely different class to what i am riding at those numbers. More than triple the HP I have sounds nuts to me and must take some careful setup to tame.
I think I have built 15 bikes to date and 5 of them are still in my stable. So, by my reckoning, that makes 10 bikes I have built custom to order for clients or have built for myself and sold.macribs said:One of the cool things about Matt's build is that he can build you your very own dream bike.![]()
Tired of waiting for Neematic? Or fancy a high powered trike? Or maybe a quad? Have Matt build you one. And that bike will be a custom bike, your very own one-off bike. You will not see one just like yours when you mock about in the woods or do some urban hooligan riding.
Me too! :lol:macribs said:I've got a large water cooler bottle where i drop my change, earmarked for a Davinci build. I've got from my wife when she got tired of hearing about your fantastic builds and how much better I could ride single tracks with such a bike. Already blown my budget for the first build I got direct orders from the queen not go wild with credit cards for a new bike, and she brought me the large water bottle![]()
So I am literally saving my nickles and dimes :lol:
