I have been working with the Lebowski controllers ICs for a little while and its time to start scaling up my project. The end goal is to develop a energy recovery system to sit alongside a race engine and supplement its power when required. The current motors are 2 Honda IMA sandwiched between the engine and gearbox. These are capable of running at 20KW all day with no problem, I have manufactured a new housing that facilitates the addition of water cooling and we have been able to push these motors 60kw each for 2 miniutes at a 40% duty cycle, this is perfect for my application.
My controller has been based around a breadboard which is not ideal for the motorsport environment, its now time to get the car off the dyno and round the track. I have been researching existing automotive controllers to see if something could be repurposed to suit my application. I have found what i believe to be the perfect donor for a Lebowski controller power stage. The Mitsubishi Outlander PHEV is fitted with a 60KW generator off the engine, the generator is capable of starting the engine. A 60KW motor is fitted to the front axle. The inverter for these motors are fitted in one unit that i have just had delivered to my door from a 2014 PHEV for £150. That is less than the price of the IGBTS alone.
Below are some images of the teardown.
This is the control board, we are not really interested in this as it is manufacturer specific, it appears to multiplex all the signals then take them out of the inverter to another black box
This is the power stage you can see the current sensors for each inverter at the bottom of the image the battery connection is the centre two terminals. This is all mounted on a 450 volt 1600uf capacitor. The capacitor is potted and acts not only as the DC Link cap but the distribution to each IGBT module
Now the important bit the power stages. This inverter is fitted with two identical power stages. In the car they are designed to operate two 60kw motors. The IGBTs are rated at 600A dc and the DC link voltage is 300v nominal, I make that 180KW each power stage 360KW total. Obviously these are Chinese rating but my rough estimates each inverter is capable of 150KW Peak.
Separate and identical power stages
Each power stage view i will discuss components below.
Direct Water Cooling for the IGBT, for those without the space for water pumps and radiators, you could consider phase change cooling.
More to come....
More to come....
