MadRhino
Use 3 U bolts, 2 on the fork tubes and one on the steering tube, and place some rubber spacers between the bag and tubes before tightening the U bolts. Then, use a 3 or 4in stem, so your handlebar is over the top of the battery bag. If the handlebar is about the middle top of the battery weight, you will feel very little weight in the steering.kafka-cloud said:I will be mounting a ping 2.5 48v 15A in a Hardigg iM2100 storm case mounted on the handlebarwith stabilization on the stem.
I'll probably use some U-bolt on the handlebar, d ring with tie down braket on case and some sort of hook to clip the case.
