betarambo
I have a pile of these batteries for my kid's electric motorcycle (Oset). I decided to order another set but can't find them. I see 20C and 30C equivalents for decent prices but they are not the same size or weight as the old 15C. For the 6s1P packs I use I see:
15C 20C 30C
weight 681 754 784
length 152 145 146
height 50 52 53
width 45 50 53
I tend to wonder if these specs are real. I am guessing that the dimensional differences are likely to be more about measurement uncertainty and how puffy a pack was when it was measured, but it appears that the weight trend is real. This could be from thicker wires if nothing else.
My main concern is the width of the batteries, but all the dimensions concern me. I designed a tight cover/box for these batteries and I have found that I have a hard time with 20C Turnigy equivalents because they are slightly wider. I made it to hold 4 of these batteries side by side and I can just barely sub in two Turnigies, but I definitely cannot fit 4 of those.
So this leaves me with two questions for you gods of electrons, pedaling, and general geekery:
1. Are the 15c variants truly gone?
2. Does it make sense that a higher C rating means more weight and maybe a little more physical size?
For reference I mount 4 batteries side by side with the discharge wires up, all on the same end like this:
IIII
Where an I is a zippy. I can just barely get away with two Turnigy 20c packs instead like this
IIii
Where i is the Turnigy. I cannot fit all 4 of them being Turngiy like:
iiii
as the width is too much.
Thanks in advance for the wisdom and also for the clever remarks about my super lame diagrams.
15C 20C 30C
weight 681 754 784
length 152 145 146
height 50 52 53
width 45 50 53
IIII
IIii
iiii
