liveforphysics
100 TW
ebike11 said:liveforphysics said:ebike11 said:liveforphysics said:The Sevcon software and programming dongle cost is like 1% of the dyno tuning labor and time cost.
This 2400Amp controller appears a lot more simple to setup, but I haven't done it yet to comment.
I know I'm preaching to the choir to most of you, but more phase current means your gearing choice compromises get so easy in doing high performance EVs. Huge phase current is how you make massive torque and still have top speed.
I seen that the ND1082400 fardriver is 2400pahse and 1350 battery....are those numbers continuous? On your controller as well?
I'm OK with 2400A phase and 1350A battery. Currently I peak ~850Amps battery and phase with similar max limits.
The 2400A phase is what matters to me, because the slow and time consuming part of the 1/4mile is when you're starting, and whole the back half of the track only lasts a few seconds (and I will still be +500A more battery current than before). +50kW more on top of a bike that already dyno'ing 70rwhp should be a solid improvement.![]()
8)
Yes 1/4 mile take off is crucial.
Is that with your deathbike motor??
Inassume you need a wheelie bar or very long swingarm
Wheelie bar unloads your rear wheel to protect from flipping over, but unloading your rear wheel isn't how to get a good 60ft time or a good 1/4mile time. I've extended the rear wheel location backwards 3 times already, and I'm happy to extend it back again if I feel constrained by wheelie limits. I've got a pair of amazing motor options for deathbike, and if the dyno shows they are saturating at 2400Amps, I will rebuild them with wider stators until the iron stops saturing.
The right amount of drag racing phase current is more. The right amount of motor power is more. Doesn't matter how much you're starting from, its unconditionally going to be more right after you get more.
