Doctorbass
Jeremy Harris said:So, if a 6 x 4110 FET controller can handle 50A OK, then a 6 x 3077 FET controller should handle around 68A with the same temperature rise as the 50A 4110 FET version. Scaling this up to an 18 x 3077 FET controller would give a max current capability of around 204A. Pretty impressive, but the real world limit might be how well the controller can drive the gate charge. Still, as these Infineon controllers use discrete component drivers, it might well be possible to do some simple changes to increase the peak gate drive current.
Jeremy
Jeremy, maybe we could work together to discover if the discrete component driver can be ameliorated!
I plan to rebuild the busbar of my first 18 fet controller with thick cooper sheet. I dont like the 18 gauge style wire soldered on the trace to cary... 65A...
I hesitate between cooper sheet and 8 AWG car ausio bulti braid wire... i'll see wich one is the easyest to work with..
Doc
