msebold
Hi! I'm doing an ebike conversion of my new 26" Fuji mountain bike installing Kinaye's MXUS 3K Turbo 60amp direct drive motor. Partially because I am unable to find the battery pack I seek at a price I can afford (and partially because I just like to tinker) I am planning on building a battery pack using 3500mah 18650 cells. The pack I am planning will use multiples clusters of 18 cells in a series charged to exactly 72 volts. This should be able to pump out about 50-60 amps continuous, which is what my motor requires. After reading several informative posts on Endless Sphere regarding similar DIY battery packs I plan on constructing the pack using about thirty-six 4-cell plastic battery holders. (See https://endless-sphere.com/forums/viewtopic.php?f=14&t=72138&hilit=plastic+battery+holders). I am not addressing here the task of constructing the battery pack, but its battery management system (BMS).
As I'm not particularly fond of fires or explosions in my garage I seek information on the BMS I will need with these 18650 cells. As I understand it, and as I hope one or more of you good and knowledgeable people can confirm, managing my DIY 18650 battery pack will require JUST THE FOLLOWING:
1. Overcharge protection (overcharging harms the cells); and
2. Undervoltage protection (draining the battery too low harms the cells)
(As this pack will use 18650 cells and NOT LifePO4 batteries, as my present ebike uses, I understand that there is no need for cell balancing.)
To take care of issue number 1 (above) I plan on purchasing Grin Technologies "Cycle Satiator), which will properly charge my battery exactly to the desired 72 volts.
I need some help with issue number 2, low-voltage cutoff. I need to ensure my planned 18-series cell battery does not discharge below 51 or 52 volts (I am still trying to determine the best recommended cutoff voltage).
I seek here anyone's recommendation for an add-on device that contains a programmable low-voltage cutoff switch.
I also seek advise on anything else I might need or which I'm missing regarding battery management of my DIY 18650 battery pack.
Thanks in advance!
Thanks in advance!
