WonderDrift
New here
Hi everyone! My e-scooter displays E30 and I changed everything except the controllers. The pack is 60v 18.2ah 16s7p and the BMS indicates: 40A nominal 65A max current discharge. Stock controllers are 25A rated and the ones I found that are plug&play are 30A each so will it work with them or it will cut after 5M?
They are cheaper than the old 25A and seems like they improved the quality of them + they’re the same size.
The scooter only have voltage sags and cut offs everything works perfectly
+ I would like you guys know that I’m not an expert but I would like to know your thoughts about my pack, if specialists pack bodybuilders are available to help me out with the best cells, the prep guys are calling me 3 times a day to ask if I decided the cells and finished the specs for providing them all: 47.5cm*12.5cm*9.2cm size
I asked for 16s9p. In this size can it be better to have another formation ? 17s or more series ? I really need autonomy and I have the possibility to use plug and play 72V controllers from the brand. Or something between more optimally sized and better options?
My pack builder is waiting for my decision for the cells to use building my pack (BMS DALY)16s 35ah but they ask the BMS identification number that I have to choose
and it’s paid so I’m waiting for my pack but it’s better to wait and sure of the pack I just need the best pack possible knowing I will use it as a racing light category e-scooter in half a year so the pack isAfter simulations I got the pack with 40T fitting all the cells for making it finally 60v40ah/72v30 so I’m a little frustrated because for the 60v40ah the guys told me even without or with the least amount of spacers they can make it but with the height of 11.3cm… because of bms and for respecting the “protocol” imposed by EU
Can I ask them to do something to make it more compact ? Like not using spacers or anything? More than 21700 5000mah cells or new 18650 5000mah is it real ?
The pack is more expensive than the scooter but that’s it so what cells to use ? I don’t have any restrictions maybe having to see if p45b are really worth the cost versus 40T.. so I can make it with 50G, 35E, lishen 4000 10c, 50E, 50S,p45b or Chinese cells. What you think about21700 Sony or a low cost super Chinese cell if they exist?
The 40T are IME just another galaxy compared to others ones, like them for my vape they are very constant and gives you all even more than others at the 10/100 battery 40T.
Vaping experience with the 40T makes me realize how they are incredibly constant, powerful, fast discharge but fast charge too..discharge fast too. confortable in hand not makes heat to have sweaty hands and don’t lose power at the sale time delivering more power way more and constance even chain smoking during my late night shift. With the Sony 21700 and the 40T the tastes is better too compared to others cells.
I’m more interested by the 50G deliver power easily than 50E which is after that they told me used in high end power machines but read here u need a very strong controller to make it draw more Amps from them vs others cells.. honestly they give me the same quotes for both but I would like to have it made with 40T so much after all that I read here.. and my vape + my friend on circuit telling me to use molicel instead (+25% sky rocket the same pack tariff but if its worth I will do that choice)
The 50G losts 20% power and capacity in cold and Here in my region mountainside it’s very cold and it rains almost 85% of the time.
