madin88 said:pete, good job. your bike looks far better with the smaller moto wheels.
mattrb said:I noticed the steel Holmes Hobbies Spoke Nipples touch the Aluminum Pro-Wheel rim. The Sacrificial anode lubricant shown in the picture is used where the nipple and the Rim make contact in order to protect against gall. The result of not using the lubricant could be corrosion or if enough heat is present, the spoke nipple could meld onto the Rim. The lubricant is Permatex Anti-Seize Lubricant item #80078
johnrobholmes said:Yes, they are steel. We will be making aluminum nipples soon, once the lathe is running.
wingsuit said:How important is lining up the direction of the nipple to where the spoke is headed. I did it correct on the rear wheel but just noticed on the front I messed it up, must have twisted the wrong dir when starting the back tension spokes. It creates a super subtle s-bend over the length of the spoke. Is this a pull apart and start again mistake?
mattrb said:What do I set my CAv2 for wheel size circumference with the 19"x1.4 Pro-Wheel and the Shinko 241?
Matt
GCinDC said:bummer! might be worth some effort loosening the all way up, and then moving them to the next nipple one by one?
cal3thousand said:For the best number, measure it.
mattrb said:cal3thousand said:For the best number, measure it.
I'm not looking for a perfect number, would you be so kind as to disclose your measurement?
Matt
You are quite right, people should have an understanding of the effects changing wheel size can have, the chassis I am putting together with 17" pro rims has 50mm of trail with the steep 69 deg steering angle i have set, if this is not enough for good stability I can lower the rear ride height a little to increase it as I built an adjustable length link into the shock linkage for this purpose. This allows me to tailor the ride height and trail measurement for any length fork.madin88 said:I recently noticed its almost impossible to ride my bike freehand. I measured the trail is very short which would explain this behaviour![]()
It seems like many kind of DH forks / frames are designd like this to enable fast and effortless steering.
take a look:
http://en.wikipedia.org/wiki/Bicycle_and_motorcycle_geometry
the longer the trail (shallow head angle, little fork rake) the better it is for the stability (freehand riding), but the steering effort will get bigger.
We all should measure the trail at our bikes before we do some changes at the wheel diameter etc. if you mainly ride fast on the street, you want to have a longer trail for stability.
arcticfly said:I have a Crystalyte 5405 in a 19" prowheel rim on my Stealth Bomber. I think I want to go back to the 5403 motor and am wondering if it is easy to change over the stator from my 5403 to the shell attached to the MC rim? Any videos made of this?
mattrb said:Phasor SR241/Pro-Wheel 19" Install is complete. This took a while but it is definitely much better then my previous rear wheel setup (26" Unicycle Rims with Duro Razorbacks - 29" OD). Going down 3" in OD makes a huge difference, I find that torque is much higher and I can easily get the front wheel off the ground. I think the speed may be about 2 mph faster. The handling seems more loose, and it might be because the tire is brand new and my old tire was worn.
I want to run a bit smaller tire than the 241/244 and had mis-read what tires were acceptable on that wide of rim, so I got some 1.4s. I'll save some weight, too. Spokes on the way...
Ch00paKabrA said:wingsuit said:How important is lining up the direction of the nipple to where the spoke is headed. I did it correct on the rear wheel but just noticed on the front I messed it up, must have twisted the wrong dir when starting the back tension spokes. It creates a super subtle s-bend over the length of the spoke. Is this a pull apart and start again mistake?
I am sorry that no one spoke to your problem. If you reduce the size of your picture before uploading it, it will show the actual picture instead of having to click on it to see it.
Here is your picture:
You are off by one spoke hole. Yes, this is a take it apart and do it over mistake. Even though the spoke will probably not line up perfectly with the holes, it is important that they go in the general direction the hole is facing.
Good luck with your wheels
Rix said:Nice Skynight John, You weighed the 19x1.4 rim at 2.55 pounds, I am wondering if the painted rims are a little heavier than the polished? I get 2 pounds on the scale. Of course this is bathroom scales. You will like the 1.4 better.
I assume those weights are backwards and that the 1.4 is lighter? That's interesting to see though that the slightly wider rim is nearly double the weight. Hard to imagine, I suspect the accuracy of the scales at that end of the spectrum isn't real good. Most kitchen scales will go up to 2-3kg, some even 5 kg. They'd be ideal for measuring stuff like this and if you happen to have one handy I'd be quite interested to see the comparison.SkyknightJohn said:19x1.85 - vs. - 19x1.4
2.55 lbs. - vs. - 4.3
(1.16 kg - vs. - 1.97)
