1959 Zundapp Bella Conversion
ZundappBella
I'm in the process of converting my 1959 Zundapp Bella 154 to electric, it originally had a 150CC 2 stroke that was pretty anemic. 7.2HP at 4700 RPM and 8.82 ft/lbs of torque at 3350 RPM. I'm close to 200 lbs and the bike has a heavy steel frame and steel sheet metal body so it really couldn't keep up with modern traffic. I don't plan on riding it long distances, just to the grocery store and the local pub occasionally so don't need much range. I managed to fit 8 Leaf modules in there and have a QS260 12inch 5000W 96V Hub Motor 45H V4 and a Sabvoton SVMC96120 Controller. I've ridden it about 25 miles so far and got it up to 51 MPH / 80 KPH so I'm somewhat happy with the performance, Probably 20-25 miles range. I may add 3 more Leaf modules in the future if I can fit them, I know I can get at least 2 more into it but I'll have to move some stuff around. No BMS yet, that'll come when I figure out if I'm going to add more batteries.
Right now I have a 3S 18650 battery that I'm using to pull in the contactor and operate the precharge relay, no lights hooked up yet. I have a cheap 3 wire DC-DC converter that puts out 12.4V, can I use that to keep the 3S 18650s charged up or do I need to add a charger? Should I just buy a small lead acid AGM type battery and use that instead?
No, it's not complete yet, lots of wiring to do, moving things around and installing screws instead of the zip ties that's holding it all together now.
