I'm hoping to get some comments on whether my plan for this conversion makes sense or if I'm way off-base on anything.
Goals:
Components I have or plan to get:
What I'm not so sure about:
based on Zero's specs on this page: https://www.zeromotorcycles.com/en-gb/fleet/police/specs I think I am in the right ballpark, but I'm concerned about the rpm numbers they're giving. The 4300 max continuous rpm is lower than I'm anticipating and I'm already having to change my rear sprocket because I can't find a 14t front sprocket for 520 chain. I have a 14t but it's for 530 chain, which means I should change the rear sprocket to match the wider chain. And that means a custom sprocket, because they don't make 530 sprockets for the SR250 sprocket bolt pattern.
Any input, comments, or suggestions very welcome. I know there is some experience with these motor/controller combinations but I can't find a lot of information from google searching yet.
Goals:
- capable of sustaining ~140 kph
- ~120 km range (at average speed more like 110 kph)
- comfortable ride to enjoy some electric cruising with a passenger
- 75-7 motor, secondhand from Steveo (is this a 75-7 or maybe a 75-7R? anyone know how to find out?)
- Sevcon Gen4 Size6 with harness and domino throttle
- 10t 520 chain drive sprocket
- stock 45t rear sprocket on bike
- 12.5 kwh battery using Samsung EV modules from batteryhookup. 24s Li-ion, 88.8v nominal, 3c continuous capable
- what rpm will the motor run with my specced battery? 88.8v sevcon gen4? what is the kv of this motor? Does kv matter so much when talking about these motors and controllers?
- what will the efficiency of the motor be running 100+ kph?
