hillzofvalp
ATTENTION: ALWAYS USE "BALANCED" MODE ON KELLY KBL CONTROLLERS! (Not "Torque" or "Speed" Mode)
Can anyone shed light on these settings as far as what it is actually doing on the technical side?
I always wondered why low end was so weak even with high phase current setting. Now this thing is a beast... it is a rocket ship. Takes on heat faster, obviously. I'm going to tune it down a little bit on motor current a little bit.
I was able to regen a good 75A from 80mph. However, I have decided to disable one controller regen and/or ABS because of this terrible sound it makes.
edit: I can definitely tell that the controller is doing power stage temperature limiting with these new settings. I think toning it down on the phase current will also help a bit here. Controller cases stay around 32-37C. The thermal limiting often goes away quickly, sometimes even seems to reset if I zero out the throttle and then reapply it. In other words, if I WOT from standstill , there is sometimes noticeable lack of thrust but then when I reach 20mph I "pretend shift" and the power returns.
In any event, this now feels as peppy as my old cromotor setup.. sad comparison, but true. Very responsive. This is the thread that led me to change to the balanced setting:
http://visforvoltage.org/forum/13530-new-kelly-kbl72401e (warning, there is a lot of bad advice in that thread)
