Ypedal
100 TW
I'm setting up 2 mean well power supplies SP-480-24's in parallel, i powered each one up and adjusted the trim pots to 29.0 volts .. paralleled both as shown :
When powered up, the fans from each unit will go high then low rpm in a 2 second pulse..... this is with no load..
Is there anything that needs to be done to prevent this ? or will it all smoothen out once i hook up a charger ( my 3010B ) .. ?
