menvert
Deesjoint said:is there a good battery supplier that you guys would recommend? One that sells the charger with the battery preferably.
The reason I went for the 48v is because I wanted a slightly faster low gear so that I could use it as my primary speed and only use high gear if needed. My commute on the bus now is roughly 2 hours to and from work, and I expect this to shave at least 45 minutes from my commute and add quality me time to boot.
It somewhat depends, where do you live, what's your budget, do you have lots of hills, are you and the bike heavy.
If cost if not a limiting factor most will swear by em3ev.com for a reliable reseller, though they only have 48v(13S) packs at 11Ah, they have 50v packs though like this 1 cell higher (14S) than a normal 48v so should be okay, and will up your speed even more...
I'll get my next bettery from BMS, postage is quite high as is delivery time and more than a few people not happy with their service, but my last one from them is 5 years old now (only issue ever was the plug amperage was too low, so had to solder in a higher amp plug), to go with a lipo pack like those i'd still get the triangle bag from em3ev
