fabieville
- Joined
- Jul 15, 2012
- Messages
- 114
I have a ebike with a 24v-72v 3000watt mid drive cyclone motor currently running off a 24v lithium battery pack.
I am planning to install a 48v or 60v front hub motor on the front wheel for the sole purpose of recharging the battery. So basically whenever the bike is in motion at a certain rpm I suspect that the front hub motor would produce a voltage higher than the 24v battery and with the aid of a blocking diode it would send the current to the battery.
The front hub motor will weight around 8-10 lbs, and it has little to no drag.
Do you think this method is feasible? Will the charging performance makes sense even with the added weight on the bike?
So in essence if I use to get a 15mph commute on my bike on a flat terrain at full throttle, with the charging method addon I will get more mph even with the added 8 or 10lbs at full throttle?
