2009/03/03 Shenzhen 3 Speed Controller @ 133v Success!
karma said:
heh just follow the red arrow sorry i didn't get the value off the resister when i removed it. flew off and hit the floor kinda like finding a needle in a haystack. i cheated unlike the gm controller this controller
Goes into lvc if you remove the resister. so what i did was add two wires and power the controller up with my voltage 52volts. one side of the resister will be the full voltage other side should drop to 3volts
anything above or below 3volts the controller goes into lvc. took about a hour to track it down there getting better at hiding the lvc.
cheers
your ca is packed and ready to ship pm me with your address when you get the chance.
sweet not if we can only find the hvc as well and yess it has a highvoltage cut off as well lol ran in to some problems with it to
Hi, I guess it's a bit outdated controller but have a question is it possible to ad a REVERSE on this controller somehow ???
Since it's a option I need badly.
Also does any one knows is this programmable and if so - how to ???
Anyone can share error code tables?
Also any chance of anyone having datasheets for chipsets ???
This info would be much appreciated.
