Ypedal
100 TW
Ok.. so i know a bunch of you guys have KMX's and i'm done being jealous, what i want to knwo is this, What model should i get ?..
I'm 5ft 7" , 190 lbs ( actually 185 atm, working on 180 ).. I plan to do mostly road, occasional off-road.
Plan is to run about 5kw, either hub or RC motor, i happen to have an Agni 95r in my hands needing a home.. but that's a bit over the hill and certainly over 5kw..
Aaaanyways.. to those of you who have done this, what did you start with and what did you change that i should just skip ahead and get right from the start.
edit :
And where do i get it from ?.. if i go RC, obviously i get it right from the source.. knock knock recumpence.... but if i go hub, the savings of buying locally or as close as possible to save on shipping factor in..
edit :
