Mongo
Crust Evasion step-through frame. initial Specs: 68mm motor, 73mm bottom bracket, with:
After a few years, it got an upgrade from 3 to 8 speeds, via a new 26-inch wheelset (Schwalbe Fat Frank tires, Alfine 8, Sapim spokes, and Velocity Blunt rims) and a Lekkie 40 tooth chainring, to fix up the chain line. The former Shimano 3-speed operated just fine, but more gear range was desired. The colors were updated, taking cues from the Harley Davidson prototype e-bike and the Bluejay Premiere. I prefer silver components, when available.
Shown is an older 13AH shark, but the frame clears a safer 17AH EM3ev replacement. The bike has a new owner, and I hope it's earning its keep.
- Fattish tire clearance with a narrowish Q., max 3" wide tire clearance (in 26")
- TRP Spyre cable brake calipers
- BBS02B mid-drive, with the bbs-fw open-source firmware
- Lekkie crank arms
- Short-reach bars/stems
- Adjustable, replaceable rear dropouts with an inboard (within the frame triangle) disk caliper mount
- 1/8 inch chain
- Steel frame tubes
