Mongo
This frameset has had many configuration lives - as of now, the build specs are as follows:
- Crust Evasion medium frameset - steel frame tubes, fattish tire clearance with a narrowish Q, adjustable, replaceable 135mm rear dropouts with an inboard (within the frame triangle) disk caliper mount. For the drive side chain stay, the frame has a short length of flat stock - fairly common on cross or mountain steel frames these days, I think. It'll clear up to about 42T (tested with a BBSHD Luna Eclipse and a BBS02 40T Lekkie - overkill for the tiny CYC Photon secondary gear case)
- 73mm English BB
- Crust Clydesdale front fork
- 52-volt 17-25AH downtube mounted tray-style batteries
- BBS02B mid-drive, with the bbs-fw open-source firmware, swapped to a stock BBSHD (see below)
- Lekkie 160mm -> Shimano STEPS FC-E5010 165mm crank arms
- Lekkie 40-tooth chain ring
- KMC X9.93 9-speed chain
- microSHIFT 11-38T 9-speed cassette, derailleur, and trigger shifter
- 20 by 2.35 Schwalbe PICK-UP front tire on a Saltplus Summit rim
- 27.5 by 2.35 Schwalbe PICK-UP rear tire on a Velocity Cliffhanger rim
- TRP Spyre cable brake calipers
- Soma flat bars
- Portland Design Works rear rack
- Banjo Brothers Market Panniers
- generic plastic front crate
