icherouveim said:
Does it have more stopping power compare with an original caliper that comes from the factory?
If its hand made where did you find o ring sealings?
I took apart the caliper from the motorcycle for parts.
The work is not different from the factory. Form was important to me.
A small report on testing.
Arrived to me long-awaited Nucular Controller on 12F, with limits battery\phase 200\250A.
Ride became much more interesting
Acceleration to 0 - 60 km\h in 4.2 seconds.
It is understood that the cooling system is not perfect =) At the first trip heated the engine to the set limit of 75 degrees and the controller began to reduce power.
The result was 1920w, the more the engine can not accept.
At this rate, in total I rode a couple of hours, then the controller broke. Closed two phases inside the controller.
Video test of the controller:
[youtube]Zd8DOx98FVQ[/youtube]
