I am currently working on a hybrid race car to compete in the 2010 SAE Formula Hybrid competition.
We have determined we will need 72 Volts, hence the 24S.
We have also determined we would like to use an Agni motor. The 95 reinforced is rated at 400 amps. Our plan is to goto about 350A for brief periods.
To produce 350A we really only need about 4 batteries in parallel (50C). Problem is that's only enough for 2 minutes, and it will drastically reduce cycle life of the batteries pushing them that hard.
I have heard A123's maintain cycle life extremely well up to about 17C and 140 degrees F. 17C * 2.3 = 39 Amps. Going with 10P to be on the safe side seems like the best choice. The endurance race is 22km, and is typically completed in around 20-25 minutes. 17C is about 4 minutes of raw full power @ 350 A. I figure this will only be used about 1/4 of the time giving more like 16 minutes of use. An ICE assist and intelligent use by the driver will put us the rest of the distance.
I have decided for weight displacement reasons splitting the pack into two and putting a 24S5P on each side of the car would yield the best results. This would allow for one BMS per side. I have seen other discussions on having a hard switch to put all packs in parallel and rigging a charger that can put out 3.7 V and 200A. Is this at all viable if we can build such a charger? I'm not holding my breath on this.
To be clear, we will build small packs of 5 batteries in parallel. 24 will be connected in series and stacked on each side of the car. One BMS for each side.
Main Questions:
1) Is it at all feasible to build 48, 5P packs? Shouldn't take too long if our team can get an assembly line set up.
2) What size wires? ~200A between the packs on each side. ~400A into controller, I assume we are going to need some really fat pieces of copper.
3) How much ventilation? I was thinking of opening the front and back of the battery enclosures and putting small fans to facilitate airflow would work fine. Would this even be overkill?
4) Should two 12S 10P packs be considered (rather than two 24S 5P packs)? This would allow us to use one BMS for the whole system. Or do we even need to go the opposite way? 3-5 BMS?
5) Any soldering advice? I've only watched a few videos on the subject. 100 W soldering gun to prevent too much heat going in. Cleaning all connections thoroughly before starting. Flux, all that jazz.
6) Would you guys recommend cutting off the green covering? My guess is it just slows heat transfer. In general you want the battery in the center of the 5P pack to dissipate through the metal into the other batteries. Would shrink wrap also hinger this process? Is shrink wrap necessary to prevent some serious shorts?
7) Anything I'm completely missing?
Please don't tell me I'm dumb and should just use Headway, Thundersky, Kokam, BMI, or LifeBatt. Those are great batteries for electric only applications, but the point of this pack is a lightweight high power assist for the ICE's abysmal torque curves. Kokams are absurdly expensive, and I know LifeBatt produces a high power battery also, but I can't find a single price quote and I have people on Ebay practically giving away the A123 26650's (Yet to be determined if these are fakes. Some test will be performed next week once bigger resistors arrive).
I plan to document our progress and will try to update with pictures as the process goes on. Thanks for any help.
Main Questions:
