Beison8000
- Joined
- May 31, 2022
- Messages
- 3
Hello Friends,
Apologies if this has already been discussed but I searched and didn't see the specific answer.
Scenario:
Scenario:
- I have one bike with 3 batteries that are in obscure locations (front loading cargo bike).
- The batteries are all 48V, two are the same pack make/model with but different amount of wear, and one is from a different company.
- They all are about 15ah. They all have roughly similar voltage sag performance under ~1000w load (2-3V sag when isolated and monitored)
- Each pack has a charge/discharge port. Each pack can be charged from the XLR port. Each pack calls for the same 54.6V 2.5A charge current
- I currently have a 3-way parallel connector attached to the discharge port of each pack and the bike functions well with this setup.
- When I recharge the bike, I disconnect each pack and individually charge, then test voltage, then reconnect. This is not ideal because it is a hassle to remove the batteries from their different location and charge individually
- I would like to wire a 3-way parallel connector with a pig-tail that I run to one mounted location where I can attach a charger, connect the bike overnight, and come back with all cells fully balanced and charged.
- Will this setup work the way I'm thinking? If one pack finishes charging first, will the BMS restrict flow to that pack, while letting the other packs finish charging and balancing?
- Will there be any undesirable backflow of current between the 3 packs with this setup?
- Am I missing anything else here? Is there a better way to do things?
