Hi friends
A 36V hub motor maybe powered at 24v using a 24v controller. i have tried this configuration before.
But the torque is very weak. If I hold the tire firmly and then throttle it, the wheel will not move even though it can spin well at no load.
I have seen 24v motors on ebikes. Its able to move a person of 80kg.
But why is it when a 36v motor connected to a 24v controller at 24v battery feels so weak? It does not feel like a 24v motor.
So, I am suspecting the reason is the internal resistance of the 36v hub motor is higher than a 24-specific hub motor.
This is why when run at 24v, the 36v motor feels weaker than a 24v hub motor run at same voltage and controller.
Please could you confirm if this understanding is correct?
Thanks.
regards
RichardT
Thanks.
regards
RichardT
