ammodave
I see hub motors at many of the ebike sites that list the motor as 250w/350w http://www.greenbikekit.com/index.php/36v-250w-gbk-100f-electric-bike-kit.html. Sorry to be a newb, but what does this mean? Is it 250w or 350w?
d8veh said:These 250/350w Ananda motors from Greenbikekit are very smooth and quiet, and at 36v with a 15amp controller, they provide a little bit less torque than the 250w Bafang SWX motors with the same controller, but they go really well with 12S lipos at about 48v and 17 to 18 amps, which is about 750w from the battery.
I would recommend the BPM 500w (216bpm version) motor sold by greenbikes. High torque, geared motor so easy pedalling, effcient motor if run at 25 amps and will make about 18-19 mph. I have one and even take it on mtb trails in thick mud and very steep hills and it is great. It was recommened to me by d8veh who has commented above. Will make 15miles with 10ah battery with light pedalling easily.ammodave said:Thanks for the info. Would this be a good motor for a first build? I'm trying to get 20mph with a 10-15 mi range (level ground) on a bike with a bike/rider wt of about 175lbs using a 36v/10.4ah battery.
T think you can forget the SWXU because it's not powerful enough. The Q100 doesn't growl like the SWXK/H motors because it runs at higher speed. There's not a lot of power difference, but I think the Bafang has the edge. As I said before, the Q100 can sustain 20mph without pedalling, even up slight inclines at 48v and 17 amps. That's my bench-mark. I can't say how long it would last like that because I normally ride at much slower speeds, so mine are still all OK. The gears aren't as big as the Bafang ones, so they'd probably get damaged more easily; however, they're cheap and it's about 20 minutes work to change the entire core of the motor, so buy a spare motor and have some fun.-dg said:d8veh said:These 250/350w Ananda motors from Greenbikekit are very smooth and quiet, and at 36v with a 15amp controller, they provide a little bit less torque than the 250w Bafang SWX motors with the same controller, but they go really well with 12S lipos at about 48v and 17 to 18 amps, which is about 750w from the battery.
Since you seem to have tried both, can you compare the Bafang motors, eg SWXK, SWXK5, SWXH or SWXU with the Q100 as far as speed, torque, noise etc? This would be with the 6fet controller shunt modded to between 17 and 22 amps with 12s lipo and all in a 26 or 700c wheel?
I have the SWXK and at 22 amps/48v it seems pretty strong but a little growly under heavy load. I have not really tried anything else yet so I'm trying to collect impresssions for my next build. I'd like to keep it pretty light and stealthy, but I'm on the big side and it is hilly here so I'm concerned that the SWXU and the Q100 may not be up to it.
d8veh said:T think you can forget the SWXU because it's not powerful enough. The Q100 doesn't growl like the SWXK/H motors because it runs at higher speed. There's not a lot of power difference, but I think the Bafang has the edge. As I said before, the Q100 can sustain 20mph without pedalling, even up slight inclines at 48v and 17 amps. That's my bench-mark. I can't say how long it would last like that because I normally ride at much slower speeds, so mine are still all OK. The gears aren't as big as the Bafang ones, so they'd probably get damaged more easily; however, they're cheap and it's about 20 minutes work to change the entire core of the motor, so buy a spare motor and have some fun.
motomech said:The Cute comes apart easily w/out special tools.
The 201 Bafang is too slow a wind for a sm. wheel.
The Q100 rear will take a 8 or 9 T. free wheel if that is important to you.
Although I like the MXUS mini best, the Q100 is a slick kit for the money.
You can read about my experiences with both, link below.
You're correct. I didn't actually try it. I took one look at it and could see that it was very small. If you have a look at the Bafang website, where they have the specifications, you'll see that it's only rated at 180-220w compared with 180 - 250w for a SWXK. We need a volunteer to test one and see exactly what it can do, but my expectations wouldn't be high.-dg said:d8veh said:T think you can forget the SWXU because it's not powerful enough. The Q100 doesn't growl like the SWXK/H motors because it runs at higher speed. There's not a lot of power difference, but I think the Bafang has the edge. As I said before, the Q100 can sustain 20mph without pedalling, even up slight inclines at 48v and 17 amps. That's my bench-mark. I can't say how long it would last like that because I normally ride at much slower speeds, so mine are still all OK. The gears aren't as big as the Bafang ones, so they'd probably get damaged more easily; however, they're cheap and it's about 20 minutes work to change the entire core of the motor, so buy a spare motor and have some fun.
I'm not trying to be contentious, but searching here and at pedelecs.uk about the SWXU only finds a post from you saying that you ordered an SWXU but it would not fit with your disk brake so you passed it on. My question is, have you actually compared the SWXU and either SWXK or Q100 in a bike, or is "forget the SWXU because it's not powerful enough" more of an estimate based on the size.
My goal is to be able to sustain a 6% grade with about 100 watts of pedaling or a bit more in a 20" wheel at 140kg all up. I'm currently leaning toward the 201 rpm SWXU at 52v with the Q100 in 328 at 45v as an alternate.
Your point about buying an extra motor to have a spare core is a good one. Does the Q100 come apart without special tools?
Well, maybe I'll be that volunteerd8veh said:You're correct. I didn't actually try it. I took one look at it and could see that it was very small. If you have a look at the Bafang website, where they have the specifications, you'll see that it's only rated at 180-220w compared with 180 - 250w for a SWXK. We need a volunteer to test one and see exactly what it can do, but my expectations wouldn't be high.
