26" rim onto 21" motorbike wheel
Bluefang
Australia, Goldcoast
Hey guys, I have a E-bike that i have been using a Pitbike front end for with a 21" motorbike wheel. I recently got tired of all the extra weight so i decided to removed the steel motorbike rim and motorbike tire and they together weighed about 7kg+ to replaced them with a normal double wall rim and a bike tyre.
Never laced a wheel before so i started with something abit different ;). First go the spokes were not quite long enough so i needed to modify the spoke holes on the hub, looking at the pics they are 15mm thick so i drilled them out to be only ~5mm thick which made them close enough that the wheel could be laced to gether. Would be alot better if the 26" bike rim was a double wall Aero design rim rather then the normal one then you might get away without drilling the spoke holes. I needed to drill the spoke holes on the rim larger, ~6mm for the nipples and 12mm for the nipple heads.
So for a cheap and easy suspension setup that will handle more abuse then you can dish out some light weight motorbike forks from say a CB90 or a small dirt bike can easily be modified to handle normal bike tires too. :mrgreen:
@SM: JRH has actually already built at least one wheel like that, IIRC, with a beefy MC-ish hub. Cant' remember if it also had a MC / Moped rim, or a bike rim, though.
Myself, I'd do things the other way round: Use a heavy-duty rim and spokes, and not care much about the hub part (probably using a bike hub). But my cargo bikes have to take a lot of pothole/etc abuse at times, when heavily loaded.
