Very good questions. Yes, and yes.r3volved said:Absolutely stellar manufacturing!
Looks like it could have came right from the factory floor
Have you thought about covering the open motor space? A nice grill plate would probably keep those nice body panel angles and still have visibility of the motor.
Did you do anything special to that charger to reduce vibration or anything?
No. However, Outrider is doing that very thing.m4s73r said:Have you played with delta/wye switching on single motors? We have a motor at work that does a wye start/delta run set up. Ive often wondered if something like that could be wired to the amps to the motor.
I can get individual parts from them for you.m4s73r said:Well at least its good to know that it can be done. Sadly, I dont think they sell part anymore, or at least they dont have a site that i can find. I have a KMX, just saving the money up to get a set up from you.
I would assume it would work on hub motors.macribs said:m4s73r said:Have you played with delta/wye switching on single motors? We have a motor at work that does a wye start/delta run set up. Ive often wondered if something like that could be wired to the amps to the motor.
Here is another thread about delta/wye switching on the fly for DD hubmotors.
http://endless-sphere.com/forums/viewtopic.php?f=30&t=25136
Matt, do you know if the delta/wye switching you are doing to your setup will work also for hubmotors?
Seems the threads I found is old so it looks like delta/wye switching on the fly for hub motors are of the past.
madin88 said:looks amazing. awesome work!
it seems like the throttle is a Magura 5k, but with different grip. may i ask from where you got it or what needs to be modified to fit other grips?
I know. It is my slow time of year, so, I am minimizing my cash outlay right now. But, I will get a GoPro soon enough.rodgah said:Looks awesome Matt,
need a go pro or something mobile to get some onboard footage![]()
Understood.Warren said:Last October I had my first hard crash on a bicycle. A dog ran into me when I was going between 20-25 mph on my upright pedal roadbike. I broke my collarbone, and shoulder blade. Slammed the side of my helmet too. The styrofoam broke into three pieces, held together by the polyester shell. Remember the energy goes up as the square of the velocity. At 35-45 mph a bicycle helmet is not adequate.
