Skippo
🔋 Established
Anyone know if the jump motor will fit a 24" rim. How many spoke hole does the motor have?
Skippo said:Anyone know if the jump motor will fit a 24" rim. How many spoke hole does the motor have?
bancars said:* Nut has *seven* sides (each side is 8mm long and is bowed in by 1mm), so it can't be tightened with a crescent wrench or a regular hex socket, but vice grips should work.
DrkAngel said:Picked up a pair with "Warped Rim" for $25 each,
BRUSHLESS CONTROLLER SINEWAVE 12Mosfet MAX CURRENT 25A RATED CURRENT 12A FOR MOTOR 500W AND TORQUE SENSOR T9 T13 T15 T17
price is for one display and controller .. the controller is sinewave model. 12mosfet. current 25A.
this model is produced to match with our torque sensor t9. t13 . ORDER THE TORQUE SENSOR HERE,
https://www.aliexpress.com/item/33030138390.html?
https://www.aliexpress.com/item/33027685086.html?
wiring
this is for motor 500w.
LIKE THIS
https://www.aliexpress.com/item/4000236301333.html?
one piece of speed testing magnetic disc
and 1:5.0 reduction ratio.
if your motor is different please set the display right
the crank works for it
https://www.aliexpress.com/item/1005002488806914.html?
and this controller has frontlight wire
and brake light wire
display: wire from the controller:
red white-48v power positive
blue white- power lock
black white-48v power negative
green white-communication TX
YELLOW WHITE-communication RX
torque sensor wire
red- -12v
green--torque sensor signal TA
BLAcK- torque sensor power negative
yellow-pedal assistance direction EBS
WHITE-torque sensor signal ADI
grey +black is brake wire , grey is brake signal, black is brake power negative,
red +black --frontlight wire
brown +black is brake light wire,
motor hallsensor wire
red --power positive
black -power negative
yellow --motor hall SC
GREEN-MOTOR HALL SB
BLUE--MOTOR HALL SA
WHITE -SPEED TESTING WIRE SS1
The motor itself doesn't require a display (it can't talk to one).Ghz24 said:I bought a few of these from battery clearing house.
I thought I had this figured out. Got 9 pin extension wire, a 350 watt motor controller, a 36 volt reclaimed "lime" scooter battery and a throttle but, testing gives nothing at the wheel
I don't get what it is I'm missing.
Do I need a display to run the motor somehow?
