35mm hub/rear wheel on EEB
Dirt biker
I'm looking to use a standard 35mm rear wheel on the EEB. is there a longer axle you can buy?
You can try eastgem they sell a rear hub with longer axle for bigger bikes running mid drives
if your talking about using a 135mm small hub motor on this frame you'll just need a few hub motor spacer washers on each side, the axle should be plenty long enough
Thanks. I'm just gonna pedal the bike around for now, without a motor, so I just need a wheel to get goin. What I have is a standard XC spec 135mm x 10 wheel . The wheel fits but the axle is not long enough.
Also, it's my understanding that when using a 135mm wheel, the wheel will rest on the dropout-spacers, which are in turn resting on the tiny bolts that connects them to the frame. Is that a problem? seems like alot of stress on those bolts.
