I'm planning to build an e-bike soon using a chopper bike. I was thinking about buying this kit http://www.monsterscooterparts.com/36-volt-1000-watt-motor-controller-throttle-premium.html
The Specs:
Motor
TYPE: Brush
VOLTAGE: 36 Volt DC
RATED SPEED: 2600 RPM
RATED CURRENT: 32 Amp
SPROCKET: #25 Chain 15 Tooth
OUTPUT: 1000 Watts
ROTATION: Clockwise
Controller
Input Voltage: 36 Volt
#Conrol Voltage: 1-4 Volt
Output Current: 30 Amp
The 36 Volt 25-30 Amp diagnostic voltage controller is an exclusive Currie Technologies design, with Currie's PWM Smart Power Microprocessor. The controller is fully water- proof, with brake inhibit power cut off.
I was just wondering if this would be good enough to get a chopper bike to go 30mph. The Back wheel would be 20". As for the gear ratio Im not sure about what would be a good ratio. And do you think it would be able to carry two people? Roughly 320lbs. If you could give me some good input that would be great!
The Specs:
Motor
TYPE: Brush
VOLTAGE: 36 Volt DC
OUTPUT: 1000 Watts
ROTATION: Clockwise
Controller
