Hi,
I got a hoverboard for free from a friend because it would not power on or charge at all (no red light on charger). I measured the battery voltage to be 17V (a 36V 10S2P pack with Samsung cells, see pictures). After opening the battery pack I tried to charge it by connecting the charger directly to the B+ and B- on the BMS (for short periods monitoring the voltage and temperature regularly). When reaching around 32-35V I was able to power on/off the board. Foot sensors seemed to work but it kept displaying a red battery symbol and beeping to signal low battery. Still it would not charge "the normal way" through the charge port. Shorting between C- and B- (as I saw in a youtube video) starts the charging but it cuts out as soon as the short is removed. I have also tried to "reset the battery" according to the manual by swiching the board on/of at certain intervals,
From what I have learnt this is likely a case of either a dead BMS or bad cells in the pack? Is there any way I could determine which of these it might be without taking all the cells apart? Or is there another way of trying fixing this problem before I go and buy a new battery?
Would really appreciate your advice!
