prjb
Hi all, unsure where to even ask this question so hoping someone might help.
Got a battery out of an electric scooter which won't take charge. After probing around, the cells do have voltage (slightly under what they should be, but if it's not charging that's gonna be about right).
Issue i can see, is the two negative connections to the charging port and the output to motor are dead... multimeter doesn't show continuity back to main battery negative. Probing the positives (at the same end) to the main battery neg does show voltage so the cells are definitely live though.
Any ideas? Very unfamiliar with this type of board, never really worked on BMS before.
Thanks in advance!
(thick wires to motor, thin are charging wires, both red pos show voltage back to B- on main board but not on their own negative wires)
Thanks in advance!
