joystix2
I have one of those 36v10ah Nimh from batteryspace.com and it has never ran with my bd36v system. It would always cut in and out. I figured the voltage was sagging really bad so I opened it up and changed the tiny 18g wires to 14g wires. Its still not working. My brother and I ran a Voltage meter on it while throttleing up and riding and sure enough it's dropping from 36v, 32v, 30v then straight to 9-10v then it shuts off. An so on... I took a picture of the the way they have it set up and found a heat sensor (I think its the white thing in the pic which is hooked up between the charging wires to the negative. I do not know what the orangeish/tan thing is on the left. I think it may be a cap but not sure. I was thinking since the warranty is shot just by opening it up that maybe I should just bypass and remove the orange square thing. Could this be the cause of my problem with the huge voltage sag? Any thoughts would be greatly appreciated...
Thanks
Ric
Thanks
Ric
