ridethelightning
- Joined
- Jul 21, 2013
- Messages
- 2,010
bionicdan said:Yeah the one I used was just pwm (for small motors?). The buck or boost ones held out nicely under throttle.
This guy has 80+ volts to deal with so I personally would just run 4x18650 that would suck around 1.5amps boosted to 35v at 500ma for his led chip. 2 hours run time there and very small package
that sounds like a good idea also.
iv got spare 18650s all over the place...
i bought a few things for the build under sleep deprived hypnosis last night in the small hours
i got a little pwm controller,
http://www.ebay.com/itm/141420463906?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
a step down transformer (could be run from a small ac adaptor that gives 12-36v output from the 84v pack, or a few 18650 as you said)
http://www.ebay.com/itm/171789331803?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and a rather expensive cree cxa3050 led, 3000k (did not want to be dissappointed with the cheaper ones as i saw they were ofted low quality/dodgy, on utube)
http://www.ebay.com/itm/172089031911?_trksid=p2057872.m2749.l2649&var=470930974840&ssPageName=STRK%3AMEBIDX%3AIT
the led is a pretty big outlay, but the other things are cheap enough im willing to try a few to get the best/compact system.
i like the digital voltage/current readout on the step down converter, but its probably not really necessary.
i was thinking the pwm could be coupled to the output of the step down to use as a dimmer, that way there wont be voltage sags etc, but its probably not the most compact system.
the last thing i need to decide on is the lense/reflector, as im not too sure the cree leds have matching lenses available cheaply(couldnt find yet)
i guess it could made from the epistar type lense/reflector with some diy adaptations.
