marka-ee
- Joined
- Mar 24, 2020
- Messages
- 245
I have an AliExpress battery charger that does 10 amps and has variable voltage and variable current. I think it's a pretty good charger overall so far because it can charge my 10S batteries and also 20S. Or anything in between. My question though is how they implemented the cooling. There is a fan on the back and the fan is sucking air out of the electronic case. Whereas then the cold air flows in through a front grill. The front grille is near the front display which consists of a neat little circular blue LED dot chaser that indicates the charge and then also indicates the battery voltage and the current being charged. It's my understanding that having a fan try to suck the hot air out of an electronic case is not optimal. This is because the hot air is thinner and thereby harder for the fan to propel out. I'm wondering if I should reverse the flow of the fan to suck fresh, colder air into the cabinet and then have it flow out of the front grill. Going across the various heat sinks inside. What do you guys think? Unfortunately, it doesn't have variable fan speed according to load. It's either on or off, but I guess that's okay. I'm just wanting to optimize things. It's my hobby
