Ypedal
100 TW
3.5v is fine, it's like 97% charged....
johnnyz383 said:As a matter of fact i measure all 16 groups of cells...almost all were 3.333 +/- .01 or .02. Thats the best ive ever had the pack balanced.
John
johnnyz383 said:Oh by the way, as for internal resistance as far as the pack is concerned, please re-read the posts. At full throttle, and with a resting voltage of 52 volts, it will sag about 43 volts at 60 f. On the ebike.ca hub motor simulator ( which is remarkable accurate) that equates to about 0.03 ohms, nothing remotely indicative of a worn out battery thats been "hammered to death"
John
Hillhater said:johnnyz383 said:Oh by the way, as for internal resistance as far as the pack is concerned, please re-read the posts. At full throttle, and with a resting voltage of 52 volts, it will sag about 43 volts at 60 f. On the ebike.ca hub motor simulator ( which is remarkable accurate) that equates to about 0.03 ohms, nothing remotely indicative of a worn out battery thats been "hammered to death"
John
?? In order to have .03 ohm IR with a 9 volt sag, you would need to be drawing 300 amps !![]()
if that 9 volt sag is at your max amperage of 45 amps, that suggests a pack IR of 0.2 ohms !
..and 9 volt sag is pretty high !
But "PACK" IR doesnt tell you a lot, you could have a near dead short in one parallel group.
You need to check the IR of each group.
Until you do, you wont know if you still have some dud cells lurking in there.
Also , you have never actually said exactly what this pack is ?
I have deduced its a 16S, 16P pack of 18650s , but what Ahr capacity is it ? ... any idea what cells are in it ?
