john61ct said:Again, please do the math for us, actual C-rates in use
i don't know how c rating is calculated
i only know some aspects about batteries.
still learning about them. :|
john61ct said:Whoops, forgot we're dealing with LFP here.
No, 3.1V is OK so long as it recovers higher.
Are you sure that BMS is designed for LFP?
Usual cutoff for cheap ones is stupid low, well below 3.0Vpc.
Get one that lets you adjust the setpoints.
See? that's how you learn.harper said:i don't know how c rating is calculated
john61ct said:See? that's how you learn.harper said:i don't know how c rating is calculated
How many cells in parallel, xP15S?
Times the mAh per cell equals pack Ah.
Actual - have you load tested?
or just accepting vendor claimed capacity?
Say 14Ah actual, then 28A is 2C.
john61ct said:Can you link to the pack?
How about the cells, and/or the BMS separately?
john61ct said:Aha, yes secondhand can be dicey.
Search for "3-lamp discharger" that and a timer is all you need for "pretty accurate" load testing,
or very sophisticated CC dummy loads are under $100
Next time be ready to load test upon receipt so you can get a refund if the seller claimed higher than actual.
Also, you may need to carefully watch your balance voltages, most BMS are sub-par in that regard.
john61ct said:Start saving your pennies now for when (not if) it needs replacing, if you get more than a year or two be happy.
Also keep researching trusted sources, sometimes even secondhand can be OK.
I would not accept less than 95% SoH for a crappy mfg, 90% is OK for the likes of A123.
eBay / PayPal offers 100% no questions asked refunds if listed as Used and they arrive Not As Described.
No matter what the seller says, they have no choice, even have to pay return shipping.
Even if seller wrote in 40-point bold red "NO RETURNS" that is a meaningless bluff, unless they state "For Parts Only".
Please do not use this excellent policy to scam sellers!
Anbudroid said:Happy to read all the above posts
Am Anbu from India
I bought used hero electric photon(48V 33AH) (slow mode 350w , fast mode 1200w) lead acid model and converted it into lithium model after several months of google i bought some used laptop batteries capacity check with littokala Lii500 battery tester. Sorted 52 batteries from 1800mA-2000mA build my 13S4P pack using those salvaged cells without BMS.
Charge the battery with lead acid charger with CC CV BuCK boost converter. Ride my bike 10km/day in slow mode (350w) ,balance cells every month with some fear in mind about fire. After 3 months of usage battery died cannot even give 3km/charge.
So that i plan to buy from reputed manufacturer and bought 48V LFP pack from MicronixBangalore(https://www.micronixonline.com/products/48v-24ah-lithium-ferro-phosphate-battery). Rated 48V30AH. When i received the battery it shows only 50.5V i ask the seller about this then only they informed me that the pack is 15S and the out put shows not above 52V .
I informed them about the battery after 5 cycles it still shows 50.7v like @harper post. I cycle the battery 30 times from Feb 2020 to till date. Battery voltage still 50.8 at full charge. Charger they provide for this pack rated 58.6v 6A.
I measure the usable capacity with watt meter (https://robu.in/product/150a-high-precision-watt-meter-power-analyzer/) its show 26Ah until the pack shutdown completely .i cannot disassemble the pack to test eaxh battery voltage because it void warrenty . just want to know is this normal ? Or either the BMS or any banks of the pack is faulty ?
One more thing to ask about its mileage. Actual mileage is 60km with (33Ah) Lead acid battery. So i calculated with LFP 30AH is enough to reach that same milage . but only got 28km/charge . confused about what causes this weird situation ?
