I would like to split the pack and run parallel 24v discharge and 48v series for charging due to material on hand (got a Foxxpower pack and charger using an ebay coupon for an excellent price). Using 48v 8a BMS balancing charger on a 16 cell 48v 10a LIFEPO4 pack, cells rated for 4c continuous no battery BMS for discharging. Finding an affordable reasonably sized high amp DPDT switch is proving difficult and I like to keep things simple so I can understand what is going on. So am not really interested in relays and the additional circuitry they would require.
Would it be safe to use Anderson power poles to manually connect/disconnect the series and parallel circuits? Provided of course that I disconnect the controller as a first step in the switch over. Or is this a bad idea? Maybe someone can recommend a decent alternative. Would like to use this pack with my current 24v BB drive until I save up enough to get a BMC hub motor or maybe a cyclone 650 w if they prove efficient.
Thanks.
Thanks.
