methods
1 GW
Oddly - if you try and find a low power (say 5W) DC-DC converter for over 100V you will be disappointed to find that not only are they not commercially available - but the chips are not even out there to roll your own.
Here is the irony... Every single switcher on earth is a DC to DC right? If you buy 10 and dissect them guess what you will find? You will find 10 DC-DC converters with a full bridge rectifier on the front end + maybe a choke and a fuse.
So drum roll please................... Each and every one of us already has what we need in our house right now
I happen to be in the market for a 5W DC-DC that can take an input range of about 70V to 150V.
I need 12V as my output - but you can just as easily find 5V, 18V, 24V, etc.
I down selected to one particular model - here are some highlights
* 50V to 400V input (I quit testing at 320V DC)
* 12V out @ 500mA
* DC Isolated
* $7 on Ebay shipped from the US
* 400V input caps
* Integrated fuse
* Output filtering
* Input noise filtering
* Low profile (aka flat transformer)
* High quality IR switching fet
* Good isolated PCB design
* 800mA @ 10V loaded hard
* 12V +/- 0.3V @ <600mA
* >5W continuous output
For the prototype work I need to do over the next few months it makes a hell of a lot more sense to just buy one of these off the shelf for $7 and use it than it does to spend countless hours trying to design a new buck circuit from scratch (that will doubtlessly cost MORE than $7). Maybe you have the time and expertise.... but me? pffftttt.... I am a good firmware engineer and a shit analog engineer.
If you need to go to lower voltage? 10V - 80V DC-DC converters are as common as herpes on Ebay. You just have to know how to search.
Anyhow - I am burning this one in. I potted it completely to get worst case heat. On my final unit I will probably let the electrolytics poke up out of the potting. I will probably snip that pesky LED too! (what a waste of energy...)
-methods
* 12V out @ 500mA
* DC Isolated
* 400V input caps
* Integrated fuse
* Output filtering
-methods
