fabieville
- Joined
- Jul 15, 2012
- Messages
- 114
My 24v e-bike needs a replacement motor. I was using a 24v 350watt my1016z3 geared motor and now the amature has failed and the brushes rub down so I am planning to buy a next motor. I was looking at this motor a MY1020Z Dayton 500w, (0.67 HP) 24V DC Planetary Gear Motor, 500 RPM. Would this be a big upgrade from the 24v 350watt unite that I had before. What would be the est. max top speed on a flat terrain using a 24v 30ah lithium Li-ion battery with a 160 lbs ride?
Also i need a freewheel with freewheel adapter for it. Where can I get one to fit the output shaft?
Here are the specs for the motor:
Our highest power 24V hobbyist gear motor packing an awesome 500 Watts of power!
This Dayton sports a planetary gearbox rather than a spur gear. The advantage is that when compared to the united gear motors (which use a spur gearbox), is that the planetary style gearbox is not only much stronger, it's also much quieter at high torque and high speed!
These have been a popular replacement for motorson golf carts, ATV's, Kids quads farm vehicles and more!
Extremely popular choice for any project requiring decent torque and speed. Easily reversible by reversing polarity to the motor!
Specifications:
Permanent Magnet DC Motor
Voltage: 24 Volt
No Load RPM: 3000
No Load Current: <2.8 Amps
Rated Wattage: 500W (0.67 Horsepower)
Rated Load RPM: 2650
500 RPM output from gearbox
Torque (Nm): 8.5
Rated Current: 26.7 Amps
Efficiency: 78%
Reduction Ratio: 6.67:1
Direct Drive (No Free Spooling)
Suitable for Forward and Reverse Operation
Base Mount Model
12 Gauge Power wire
Specifications:
Voltage: 24 Volt
No Load RPM: 3000
Torque (Nm): 8.5
Efficiency: 78%
Base Mount Model
12 Gauge Power wire
