simon.s
So, been reading here on and off for - well - ages now, and whilst there's a metric shedload of really really good information, there doesn't seem to be much interest in DIYing along the vivax line. I'm guessing that's down to the low power side of things and complexity of the drive system.
Here's my dilemma. My commute to work is 16 kilometers each way, up a class 1 col that the Tour de France hit on a regular basis. As I work at the top of the Col, that means doing a 900m climb in the morning, and a 900m descent in the evening. I'm capable of doing it, but I'm not Lance Armstrong : even on my road bike my average speed is <11km/h going up. That means an hour and a quarter commute, at best, in the morning, so leaving the house at around 5:30 am in order to be there on time, and even that discounts the possibility of a puncture. Given that riding up means reaching work utterly knackered, my job is quite physical and by car it's an easy 20 minutes, it shouldn't be too hard to guess which option gets taken 99% of the time.
Now, we've just bought an "off the shelf" ebike for my wife, a Cube Reaction Hybrid HPA Race 500. Hardtail 29er MTB, 250W Bosch mid-drive. It's a goddamn rocket ship, at least up to 25km/h where the EU regulations kick in and cut off the motor, but too small for me (she needs a small bike, I need a large). Still, last day off, I rode up the col on it, and apart from the uncomfortable aspect of having the saddle too low and my knees scraping the bars as I pedalled, it was kinda fun. Plus, I got to the top without sweating or going above the "eco" assist mode. Actually, that's a bit of a lie, I did briefly try "turbo" mode and it scared the crap out of me. Door to door - 37 minutes.
So, I figure I don't need some 1000W monster, 200W should be more than enough.
So, I'm kinda sold on this. But I'm the kind of guy who likes building stuff, tweaking things, and taking things apart. Plus, I've already got bikes - an early 2000s "Bertin" road bike and a late 90s "Sunn" hardtail MTB. The idea of going totally stealth appeals to me. €2K+ for a vivax install, however, does not appeal to me. Friction drive a la Kepler would be OK, except in winter with studded tyres it might be a bit off.
So, why not do an "in the seat tube" setup myself?
My choice for host bike ideally would be my Sunn - it's already modded for disk brakes, and I can't see myself riding up the col in the snow on 700x23c slick tyres. Otherwise I have a Scott frame lying about, but it doesn't gain me much (more on that later) or I can find a cheap piece of crap to experiment on. I have precision machine tools at home and access to a load of big toys at work (mig, tig, oxy-acetylene, 60 tonne hydraulic press, etc). Tooling and fabricobbling doesn't scare me.
So, what I'm thinking is:
- max ~200W usable power at the crank
- pedal assist, not throttle.
- peak assist power somewhere around the 30-40 rpm mark at the crank (rider struggling), no assist beyond say 90rpm (spinning)
- inrunner motor + planetary gearbox in the seat tube
- modified cartridge bottom bracket integrating freewheel and internal drive gear
So, what's the hard bits?
Gearing is pretty easy once I work out the ratios needed. A 3:1 bevel drive on the crank shaft, and a 2 or 3 stage planetary gearbox, job done for a pretty minimal loss of power, a 2 stage planetary and a bevel drive should run somewhere around 90% efficient.
Smaller diameter motors run higher rpms per volt and lower overall power. As an example, for the Turnigy XK series, a 24mm diameter motor gets you 350W at 4700KV, a 28mm diameter motor is 800W at 1980KV, 1400W at 3850KV. But guess whose frames will fit a 24mm motor and not a 28mm motor?
Seat tubes aren't notorious for being well ventilated. Shoving a motor down there and running it full chat is liable to result in an expensive meltdown. It seems to me that running, for example, a 1400W motor a quarter of it's rated peak amperage should be a win, over running a 350W motor at 100%, no?
Smaller motors want less volts. Less volts = less weighty (and less expensive) battery packs. Using the turnigy motors again, 24mm motor = 3S pack, 28mm motor = 4S pack. 10AH of 3S pack should be able to be hidden under the seat, or in a bottle cage tool pack type thing.
I don't want a throttle, just pedal assist and a subtle on/off switch. Butchering the bottom bracket probably precludes using a BB with inbuilt torque sensor, though. Not sure about where to go with that, or what solutions exist.
Hell if I know what to use controller-wise. I'm guessing a straight RC ESC ain't gonna cut it.
There's probably a bunch of stuff I'm missing here, or just plain wrong about. Please feel free to enlighten me, tell me I'm an idiot, etc.
