Beagle123
Hi:
I'm trying to install a 52t sprocket on my bike, but the teeth of the sprocket are rubbing against the frame. In this picture, you can see that if I tighten the retaining bolt, the teeth of the sprocket will contact the white bar on the frame. Is there some kind of spacer I can use? I'm trying to locate a large washer (1 3/8 inches ID) to space the whole crank about 1/8 inch to get clearance.
Also, I purchased a 46t sprocket too. I doesn't have the same problem. However, that sprocket is for a single speed bike that uses a thicker chain. This sprocket is too thick to be used with a normal mountain bike chain because the skinny mountain bike chain can't seat properly on the teeth because of the thickness of the sprocket.
I'd like to find a supplier for a working sprocket for this bike. When I get a good model, I hope to sell them to others. Does anyone know a good source of 46t-52t sprockets for $20-$30? I'm trying alibaba.com, but I know the reputation.
How do you guys do this?
Thanks,
Eric
Thanks,
Eric
