[$59] Used Bafang front hub motors 36v/48v rated for 350w. No spokes. (bafang fm g020.350.d)
Los Angeles
Official name: Bafang fm g020.350.d
Original price: ~$210
Specs:
Condition: Lightly used (under 100 miles of pedal assist, meaning the nylon planetry gears are intact and had little use)
Some scratches and scuffs may be visible on some motors. They are due to handling, not usage.
What's included: Only the motor. No spokes, no axle mounting hardware. Some disk brake mounting screws may be included.
Position: Front Motor
Wheel Diameter (Inch): 20/26/700C/28
Construction: Gear drive
Rated Voltage (DCV): 36/43/48V
Rated Power (W): 250/350 (max recomended power usage 600-700 watt)
n0 (Rpm): 325 ; 245
nT(Rpm): 290; 205
Max Torque: 45 N.m
Waterproofing: Water resistant, not fully water proof.
Efficiency (%): ≥ 80
Color: Black
Weight (kg): 3.3 (7.26 lb)
Noise Grade (dB): < 55
Operating Temperature: -20-45℃
Mounting Parameters
Brake: Disc Brake
Installation Widths: (mm / OLD) 100
Max. Housing Diameter: (mm) 158
Cabling Route: Shaft Side, Right
Cable Length(mm), Connection Type: 250 G9.1
Spoke Specification: 36H*13G
Tests & Certifications
IP IP X5
Certifications ROHS / CE
Salt Spray Test Standard(h) 96
