RoliRoliRoli
🔋 Established
my scooter shuts down after a minute or so of load and it was running fine until my throttle display /instrument panel had broken and I replaced it with a JP-24-60 which worked when i programmed the P setting for it to be of the correct voltage. I did notice though that my top speed wasn’t quite right for I was capable of getting in the 50s on flat ground.My cells shouldn’t be misbalanced because when I charge it gets to 67.3 when my charger light. Comes on green for full charge. I did mess with the P- settings again and raised the undervoltagge cutoff to 60v from 50v hoping to get my speed level back up but my scooter wasn’t fully charged and ended up shutting down. That was because my scooter was prolly only holding 55-59 volts and from that day i have been having problems.today it died at 64 volts and I brought it in and tested it from the battery to controller xt60 and got 55 volts , then Other connector 48.5 volts .I currently working on it as I speak snd hope that somebody here can give me some help advice feedback …I want to diagnose the controllers but am unsure how.I have Everything unhooked. Besides the 3 hall sensor wires which are sealed with heat shrink over maybe
buttconnectors ,I do have a fluke voltmeter so if anybody can assist me with what to test for my guess is start off to check continuity from the wires coming from the dash first. Maybe there is something loose drawing amperage from the battery?? The voltage will go from 67.3 down to 63-64 in a minute then shut down from rhere.
