Help ..I had Wrong value in P-settings voltage cutoff damaged my 60v battery? How do I
RoliRoliRoli
🔋 Established
USA
I have a tiF galop 60v 2800w dual electric motored scooter that I had posted before about upgrading throttle display/instrument panel. I bought a J&P 24-60v that I believe elsewhere is called QS-S4 and for it to work I had to program the Psettings voltage cut off.I had it rated for 50v and it ran fine but it still wasn’t as fast as the factory one I had before and I believe what had happened was it was unlocked before and when I installed the new throttle it factory reset the controller to use the speed limiter as it was when it was sent from the factory.the website advertises for them to go 28mph and to contact customer service after shipping to remove speed limiter (I am second owner) So I have been looking and browsing all over to find the tutorial on how to get it back to how the previous owner had it which was fast! 55mph easily and so I tryed increasing the voltage cutoff with the battery abiut half way discharged. the good thing is that the throttle display is rated for a maximum of 60v so it shouldn’t be so bad hopefully! So mid ride my scooter shut down because I set the cut off to 60v and the scooters voltage was like 54- 55. I had to charge it back up with the charger when I got home and then it went right up and charged like normal.So now it’s dying out of no where now like going up a hill 62 volts a the way down to 5v and it’s happend abiut 3-4 times total. So Im pretty sure I have misbalanced some cells somehow but I don’t have a fancy fly charger so I just left it on the charger for now and am gonna leave it for abiut 48 hrs….what else can I do???
Do you have a multimeter?
Can you open the battery to check the individual P-groups?
Does the battery have a BMS you can access to see cell voltages?
