DCDreamer
I'm doing a first build...definitely at the beginning stages and definitely learning a lot. I'm looking at this motor/conversion kit for the a 65 Honda Dream.
Maximum Power 12kw Electric Motorbike Motorcycle Conversion Kit - Buy Electric Motorcycle Motor Kit,Electric Motorcycle Motor Kit Product on Alibaba.com
Was considering the hub motor, but read a few things that convinced me to go the mid mount motor ( I can do some basic frame/motor hang building. The Dream frame is actually fairly light once you drop the motor and the stamped steal construction is fairly amenable to mods.
Looking to build a bike for around town.. errands, commuting etc. Might have to run from on exit to the next on the Beltway for convenience. So it will need to do a decent clip for a short time, but mostly riding city streets--40 to 50 mph top end. I think the 3kW motor will be plenty fast.
What are the relative benefits and liabilities of the 60V vs. the 72V? And are there any suggestions for battery setups? Would love to get as much run time as possible out of the setup, but not looking at super long rides. I think there is sufficient room to get a pretty decent size battery pack. Will probably use the tank as cover for the controller etc. might even be able to get some battery cells in there.
Another crazy idea a friend had was to add a small propane generator (hiding small tanks under the gas tank). I personally think it's a little far fetched. Any thoughts?
