frk1206
- Joined
- Apr 22, 2022
- Messages
- 37
Hi All!
Wanted to share with you folks a crazy ambitious (to me) build to create a super fast comfortable street bike that could do 40-50 miles on a charge and be able to utilize the growing number of L3 CCS/Chademo stations to get 20-30 miles of range in about 15 minutes. Yet weighing under 400lbs so that its actually fun to ride. Calling this a prototype since if it actually works and there is interest i'm thinking of doing it as a startup/commercially. There is nothing else out there that does this - Zeros are heavy and only support L2 while Energicas are heavy AF and support 1C max. Neither is fully usable without incurring a lot of mental load in trip planning. I'm trying to build a tesla of motorcycles where you just don't think about the battery - since charging is SO fast and painless.
Currently trying to figure out if I use an existing frame (ninja 650 or so) or get a custom frame built locally. Thinking of going all out with the parts here mostly cuz i'm a nerd as well as a adrenaline junkie:
- Emrax 208 Liquid cooled motor
- Cascadia CM200DX
- Custom 94S5P Liquid Cooled Battery pack using 21700 LG/Pan/Tesla/Molicell cells. 360V nominal / 9kwh cap
- Orion 2 108-cell BMS with Chademo support
- Custom stuff for CCS support
Putting this out there for some comments / feedback on what you guys think of the build. I've done EV conversions before but never a motorcycle and never something with that much voltage.
My questions are mostly centered about battery pack creation:
- Whats a good spot welder to use? Should I get the amazon/chinese ones or is Kweld the best? Don't mind paying a bit for good stuff.
- Whats a good battery / vendor to use for 21700 cells that would give me 10C discharge / 2.5C charge? Molicell seems to be the only one thats available and touting 3C charge. Any experience with these? Seems like a lot of folks use them nowadays?
- I'm looking to copy the tesla modules in their construction / water cooling. Any tips for manufacturing this pack? I'm thinking of 3-d printing the battery holding structure and then getting water-cut aluminum plate for the connections. The aluminum plate will have holes which would let me weld fuse wires to this plate. Kind of exactly what tesla does.
- I'm also looking to copy Tesla's water cooling. I need water cooling since i definitely need to charge at 2-2.5C. How do I get Tesla style bent copper pipes fabricated? Whats a good material to cover the copper tubes with that'll isolate them from the batteries but still have thermal conductivity?
- How do I make sure I don't die while building this? Going to get rubber high voltage gloves and boots and tools - anything else?
- Does it make more sense to build the battery string in series? so something like 24S5P Battery modules wires up in series? Whats the best way to connect them in series? Just wires or solid bus bars?
- Do you recommend I put a circuit breaker in each module so theres no sparks flying while connecting them in series with bus bars?
- Do you guys use a thermal camera to check how hot the battery pack is getting? If yes is there one you recommend?
Here's a (bad) cad drawing of all the big stuff on a Yamaha FZ1 frame. This was hand measured (and hand drawn) by me so bear with me
Future ones would be 3d scanned for accuracy. For orientation the motor is where the engine output shaft would be. Controller on top is where the tank would be. This one only has 4 battery modules. Most likely the motor is going between the swing arms though so there should be even more space:
https://cad.onshape.com/documents/5e50b1ea9e8aaf8a7f80a0ba/w/a083a3c302f8adf693aa27c8/e/23813a56fe78272c0e643803
- Cascadia CM200DX
